DJohnson88
Sep 24, 2018Aspirant
Nighthawk x6s ac3000 WiFi extender 5ghz issues
I purchased a Netgear nighthawk tri band WiFi extender x6s ac3000. During setup I was only able to register 1of my 5ghz WiFi signal, would not give the option to register the second one. My WiFi rout...
DJohnson88
Sep 26, 2018Aspirant
Maybe register was a bad choice of words to describe. During the initial out of the box setup/configuration, when I was instructed to select the wifi signals I wished to extend I was only allowed to use two. So your saying my second 5ghz is just for backhaul and won't be boosted like the other two signals?
Sep 26, 2018Guru - Experienced User
The EX8000 has Fastlane3 built in (not selectable). Ordinarily it will dedicate one of the 5G radios as the backhaul. In most cases that's what you'd want, as it gives the best performance.
There might be some cases where it fails over to a different mode, but Netgear hasn't said what those cases are.
