JayLo
Jun 10, 2018Aspirant
Nighthawk X6S EX8000 Issues
EX8000 - firmware updated, unit drops the connection without continuous use, if I turn off the extender, the connection from router works fine.
- Jun 12, 2018
After over an hour with tech support, it was concluded the unit is defective.
:mansad:
DexterJB
Jun 11, 2018NETGEAR Moderator
Hi JayLo,
Welcome to the community!
1. It is recommended that a factory reset is done after a firmware update.
2. Does the issue persist on both bands (2.4GHz and 5GHz)?
3. Does the issue persist on all your wireless devices?
4. Have you tried changing the wireless channel of the main wireless network?
5. When it drops, does the extender still broadcast the wireless network?
Dexter
Community Team
- JayLoJun 12, 2018Aspirant
:mansad:
- flyturboJul 06, 2018Apprentice
I have reported a similar issue like the one you experienced and just came across your post. Do you have a number I can call tech support?
- Eric_CartmanJul 06, 2018GuideMy brand new Night hawk X6 R8000 not sure how it differs from your X6S EX8000 model.
Work amazing for 2 weeks then started to reboot every hour or so.
Tech support in India just told me to replace where I purchased . So I swapped it over for a new R8000 fingers crossed.
- flyturboJul 13, 2018Apprentice
I'm having same issue and here are the answer to you question; I also opened a case with Netgear and its been 7 days since I received last email and haven't heard anything.
1. It is recommended that a factory reset is done after a firmware update. Done
2. Does the issue persist on both bands (2.4GHz and 5GHz)? Yes
3. Does the issue persist on all your wireless devices? Yes
4. Have you tried changing the wireless channel of the main wireless network? Yes
5. When it drops, does the extender still broadcast the wireless network? Yes, clients connect to extender but no Internet, some clients that always stay on don't ave the issue but if they get restarted, they connect but don't have access to Internet.
