EamusCatuli's avatar
EamusCatuli
Nighthawk XR1000 and Mesh Help
 I have a NETGEAR Nighthawk Pro Gaming 6-Stream WiFi 6 Router (XR1000) - AX5400 in my current home of 1500 sq ft and works fine.  It's all wood and drywall and compact so I still get decent speeds in wifi all the way on the 2nd floor as the router is in the basement.  We are moving into a house over 2x the size, about 4000sq ft and much more spread out.
I am looking for a mesh network that I can use with the router.  My questions are:
Do I still have to connect the "router" that comes with the mesh network to the modem or can I use it as a satellite off my Nighthawk?
No brick, how many satellites would I need to cover 4k sq ft?
Would it be better to just use extenders?
Is the NIghthawk Mesh network compariable to the Orbi network?
Thank you for any help!!!!!
EC
  • plemans's avatar
    you can use mesh extenders but I usually advise people to avoid them and go with a full mesh system if they think they're needing more than 1 extender.
    how many do you need? Depends. Each home is different. the nice thing about mesh system is you can add satellites pretty easily.
    The XR1000 isn't a mesh router. so it doesn't integrate with mesh systems.
    If you're wanting to retain the gaming features of hte xr1000 but have a mesh system, you can always add a mesh system like orbi to it and run the orbi in access point mode.
    then you retain the benefits of the DumaOS while still having the coverage of orbi.
