plofre's avatar
plofre
Follower
Jun 03, 2015
No configuration page on WN3000RP
Hello,
my ISP replaced my old modem and NETGEAR router by a new modem-router that performs both functions.
Now the extender provides an extended WLAN (with _EXT on the end), but when I try to connect a computer to this extension, the passphrase is rejected.
I tried to reconfigure the extender, but when I connect the computer by cable, open a browser and put in the URL "www.mywifiext.net", no configuration page appears.
What can I do?
Thanks in advance
plofre
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    When you connect the computer to the extender by Ethernet cable power the extender off then on again so that the computer picks up IP data from the extender, and if you have WiFi on the computer make sure that it isn’t associated with any network.
  • Could you try to disconnect the LAN cable then try the wifi connection.
    On successful connection to _EXT type the below, it worked for me
    htttp://mywifiext.com
