pic_az
Nov 17, 2018Aspirant
No Internet Access on WN3000RP
Help. I have reset the WN3000RP and reinstalled and still get connected but no internet access. I have searched the internet to no avail. Any ideas? Firmware is current on both Router and extender.
DexterJB
Nov 18, 2018NETGEAR Moderator
Hi pic_az,
Welcome to the community!
1. Please indicate the exact firmware version of the extender.
2. Does the extender appear as an attached device on the router UI?
3. Was it working before?
4. Does the issue persist on all the devices that connect to the extender?
5. Are your devices able to go online when connected to the main network?
6. What is the status of the extender LED's?
Dexter
Community Team
- DexterJBNov 21, 2018NETGEAR Moderator
Hi pic_az,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- pic_azNov 21, 2018AspirantHi Dexter,
I am still having the issue. I need to get the previous you asked for. The extender worked for years when I was using WPS for or security. Once I up'd the security I started getting 'No Innternet' on the extender. I will try and get info tomorrow. I remember it being the latest version I could download.
Thanks,
Joey
- pic_azNov 23, 2018Aspirant
Hi Dexter,
In response to your questions:
1.0.2.64_1.1.86
Yes it does
It worked when using WEP security
I only have one laptop that is wireless. I found this when I could not connect my Ring door bell to the extender.
Yes the laptop and the Ring bell work fine when connected to the main router.
All led's are green.
I just wiped the extender clean and restarted. This time the Genie app came up instead of an older app. I plugged all the data in and 'wa la' it is now connecting. I must have tried that 5 times last weekend to no avail. Is there a later firmware?
Thanks,
Joey
