Fkyounggs
Sep 28, 2016Aspirant
No led lights
I have ex6200 with no led lights showing, only top Netgear light comes. Tired factory reset but no success
- DarrenMSr. NETGEAR Moderator
Hello Fkyounggs
Are you able to access the ex6200 settings?
DarrenM
- FkyounggsAspirantNope
Sounds like the device may of gone bad I would suggest to contact Netgear support if the ex6200 is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
