GuevaraNL
Sep 07, 2015Aspirant
No Wifi although 2.5 GHZ / 5 GHZ links rate green (EX6200)
Hi everybody, here my first post in this community :smileywink: I am a newbie with this and it would be nice when some of you would help me to solve this problem i have with my EX6200 .. I ha...
nhann
Sep 08, 2015NETGEAR Employee Retired
Hi GuevaraNL,
Welcome to the community!
Can you please confirm that your EX6200 is running the latest firmware? You can check by connecting to the EX6200 and logging into www.mywifiext.net
Are you able to connect any other devices to the EX6200?
Please also confirm that you are able to connect your phones to the router.
You can try resetting the network settings by following Apple's page:
https://support.apple.com/en-us/HT204051
GuevaraNL
Sep 09, 2015Aspirant
Hi nhann
No it is not .... The problem is that i not know how to do that. When i try to connect to the EX6200 and choose for the _2GEXT on my device and go in Safari to www.mywifiext.net i got a message that Safari cannot open that page because there is no internet connection ... :smileyfrustrated:
I did reset Network Settings from my iPhone 6+, it didn't work. I tried a reset of the WNDR3700, it didn't work also. Strange enough everything worked fine three day's ago with strong Wifi-signal
- nhannSep 11, 2015NETGEAR Employee Retired
Are you able to test other devices other than the iPhones on the EX6200?
You can connect an ethernet wire from a computer to the EX6200 and log in to the web browser interface.(www.mywifiext.net or 192.168.1.250)
Once that is done, it is possible to update the firmware and configure settings.
Please also try changing the WiFi channel on your WNDR3700: http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-changing-channel
- GuevaraNLSep 13, 2015Aspirant
Hi Nhann
Problem is solved by my brother-in-law ... What he did i don't know exactly, but it is working again now. He suffered the same problems as i did here, but after making a new connection he got it running ... He also discovered that i already had the latest firmware installed, so you see i am not an expert with this ;)
But thanx anyway for your support, i really appriciated it! :)
