ksikelni
Nov 12, 2021Follower
Non Cellular Wireless Wi-Fi Extender/Booster Help
Does anyone here use a wireless “inside the trailer” booster to help with campground or home driveway weak Wi-Fi signals? Don’t want to run wires from the outside-in. Just looking for a good signal booster that will help connect my wife and my tablets and maybe a smart TV. Lots of products out there, but we’re looking if anyone has one they really like and have minimal trouble with it. Any help would be appreciated.
1 Reply
Problem with RV's is they're basically a metal can. And the metal blocks wifi very well. Sometimes putting the extender/router in a window can help with this.
The other issue is some RV's parks require you to connect and login with terms and conditions. They don't let you just use a standard wifi extender. (not all parks are this way).
So if you're moving around alot to different parks, I'd actually recommend more along the lines of a travel router that supports WISP mode.
WISP mode allows you to connect to a wireless network and use it as a WAN port. This lets you go through the terms/conditions without issue.
Sadly netgear hasn't made one in years that supports wisp mode.
