NG17's avatar
NG17
Tutor
Jul 29, 2017
Not a secure connection
AC1200 EXT6200 extender - Can connect to the internet thru the extender both wireless and with an ethernet connection.
when trying to log on to "www.mywifiext.net" my IE says it is an unsecure connection and won't allow it. i have added it to my trusted sites and given it all the permissions and it still won't allow it. takes me to the log in page  for a user name and password which i don't have since i haven't set one up yet. have used Internet Explorer and Fire Fox, neither go to the setup page.
any suggestions? do i really need to set up the extender?
  • it took resetting the extenter 5 times to get it to sync up but it finally did.
    finally allowed me to go to the set up page.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Try admin/password for the login that is the default.
    DarrenM
    • NG17's avatar
      NG17
      Tutor
      Already tried that. it just says....
      "Username and password do not match"
      • DarrenM's avatar
        DarrenM
        Hello NG17
        You would have to factory reset the unit and do the setup again if the login is not working.
        DarrenM
