Vijayrchandran's avatar
Nov 29, 2022
Not able to access configure EX6110
Have a couple of problems with my EX6110 WiFi Range Extender.
1. I am getting a security warning when I try to set up the extender,
2. If I do ignore the warning & try to set up the extender, it doesn't recognize the 5.0 GHz Wi-Fi. No issues with 2.4GHz though.
  • Vijayrchandran's avatar
    Vijayrchandran
    Feb 25, 2023
    If anyone else facing this issue try this.
    Instead of entering the site address enter the IP address (192.168.1.250).
    That worked for me. The only down side is that once you configured the extender you cant use this trick to enter the extender.
    Vijay.
  • olympos1625's avatar
    olympos1625
    NETGEAR Employee Retired
    Hi @Vijayrchandran,
    Thank you for reaching out. We are sorry for not being able to get back t you immediately. Are you still having this same issue with your Netgear extender?
    Please do not hesitate to let me know if you need further assistance.
    Oliver
    Community Team
      Vijayrchandran
      Yeah. Still getting the same message whenever I try to get into the extender.
        Vijayrchandran
        Vijay.
