mahajanakhil
Feb 18, 2025Aspirant
Not able to access mywifiext on Mac because I enabled HTTPS
I enabled HTTPS for mywifiext.local and that seems to be the worst mistake of my life 🙂
This site can’t be reached
The web page at https://mywifiext.local/ might be temporarily down or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE
There is no way I am able to disable HTTPS.
I searched this forum. I came across a solution but it seems to be for Windows.
did you try using the ip address for it?
Or you could simply factory reset and reinstall.
- mahajanakhilAspirant
Yes I did. It did not work.
You tried factory resetting?
