Soundbooth's avatar
Jul 30, 2015
not accepting password
I changed my router password so now I need to get the extender working again. I pushed the reset button, went through the set up wizard again and entered the new router password.  I completed the set up and all devices can see the extender but the extender won't accept the new password. This is the WEP keycode password, not the router or extender log in passwords. I've double checked the extender set up and the wireless device, I put the same password in both places and it matches the one on the router. Why isn't it letting me log in?
  • I did check "use the same password." I was able to get into the firmware dashboard. I did everything anyone has ever suggested in the numerous forums I've checked when researching this problem. Then I found it. - in the set up wizard there is a place to enter the router's password - it says "passphrase" with a box next to it (and next to that box is a icon you can click on that says "generate" ) Turns out that is NOT the box in which to put the password. In goes in the box below that says Key 1. Why in God's name that is supposed to make sense to enter the password where it says Key 1, vs the box that actually says "passphrase" is beyond me.
  • I am having similar issues. The extender found the network (WN3000RPv3). On a mobile device I enter the network password and get an 'invalid password' response. There is no doubt that the password is correct – it's printed on the router label. There is no possibility that I've entered it wrongly (over the half dozen attempts - with 'display password' checked). The connection was made via WPS. I'm using an iMac, OSX 10.10.4 and the ISP is Plusnet via their Technicolor Router.
    If I attempt to use the browser to connect to the extender I get a VERY annoying response: "Ooops! It seems you have navogated ot this page by accident." No, I'm merely following the instructions.
    I'd be most grateful for a clue or two.
    • Soundbooth's avatar
      Soundbooth
      Tutor
      I'm wondering if it might have something to do with resetting the extender. I did a reset, but perhaps didn't hold the reset button in long enough to wipe out the stored password. Not sure, I'll have to try again but I can't get there right now, it's at another office. Did you reset the extender?
        Soundbooth
        Tutor
        Oh, the other thing I am going to try is temporarily removing the password to see if I can connect through the extender when no password is needed. If I still can't connect the problem is something other than the password itself.
