JLuigi
Oct 13, 2015Aspirant
not accepting password
I have purchased a wifi extender EX6150 I have connected to my router through WPS but when I try to connnect a device the extender won't accept the same password as my router. I pushed the reset ...
nhann
Oct 14, 2015NETGEAR Employee Retired
Hi JLuigi,
Please factory reset your EX6150 (page 41 of 50):
http://www.downloads.netgear.com/files/GDC/EX6150/EX6150_UM_7apr2015.pdf
1. Insert a straightened paper clip into the hole of the Factory Reset button and hold it for about seven seconds.
2. Release the button
3. The extender resets and restarts. This process takes about one minute.
Place the EX6150 in the same room as your router (move it to whereever you like after the installation).
Please install using the Web Browser setup (page 11 of 50)
When logging into mywifiext.net, please confirm that you have no other ethernet/WiFi connections to your computer. Only connect to the NETGEAR_EXT network.
