Larspeter
Mar 29, 2016Follower
Not accepting router's password
Attempting to access the new WIFI networks (NETGEAR_2GEXT or NETGEAR_5GEXT)
The Extender is connected to the Router via an ethernet cable
Problem:
The Router's network key is not accepted ("incorrect password")
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Larspeter
Have you tried to change the security type on the extender or just to test it have you tried to remove the security to see if the devices will connect?
DarrenM
