Petersx
Oct 16, 2018Tutor
Number of Device Limitations using EX7000 WiFi Extender
Hi Folks, we have a EX7000 WiFi Range Extender that is only allowing around 10-12 connections (all Lenovo tablets) and when we reach this limit, we cannot log on any more units (we have 16 in total)....
Petersx
Nov 23, 2018Tutor
Hi, problem solved as the modem upstream had a default 16 connections set. Changed to 64 connections on the modem and everything is good now .
Thanks all for your help :)
DeeBeeEff
Mar 24, 2019Aspirant
I know this has been several months, but I am having a similar problem. I use the EX6200 Range Extender in Access Point mode.
I can't find anywhere in my upstream modem where I can change the number of connections and I was curious if in general you can tell me where you found it on yours, as most modems use basically the same layouts and terminology.
I know this isn't much to go on so I really appreciate your time and any ideas you might have.
Thanks,
Dave
