chairman212121
Apr 28, 2018Aspirant
Old Firmware for WN2000RPT v1
Hi,
Anyone know where I can get the old WN2000RPT v1 Firmware: version 10.0.0.2
Apparently this solves the constant disconnection issued. Currrently on 10.0.0.24 - nighmare!
Thanks
chairman212121
Forget to mention in above post that it needs to be european Firmware (for Spain) and NOT North American. Thanks.
DarrenM
May 03, 2018Sr. NETGEAR Moderator
I am looking into this will let you know if I can find a Non NA firmware.
DarrenM
- chairman212121May 11, 2018Aspirant
Hi Darren,
Any luck finding European firmare?
Thanks
- DarrenMMay 14, 2018Sr. NETGEAR Moderator
I will check on this again.
DarrenM
- DarrenMMay 22, 2018Sr. NETGEAR Moderator
This link should have the firmware that you are looking for.
http://www.netgear.es/support/product/WN2000RPTv1.aspx#download
DarrenM
