chairman212121
Apr 28, 2018Aspirant
Old Firmware for WN2000RPT v1
Hi,
Anyone know where I can get the old WN2000RPT v1 Firmware: version 10.0.0.2
Apparently this solves the constant disconnection issued. Currrently on 10.0.0.24 - nighmare!
Thanks
DarrenM
May 03, 2018Sr. NETGEAR Moderator
I am looking into this will let you know if I can find a Non NA firmware.
DarrenM
chairman212121
May 11, 2018Aspirant
Hi Darren,
Any luck finding European firmare?
Thanks
- DarrenMMay 14, 2018Sr. NETGEAR Moderator
I will check on this again.
DarrenM
- DarrenMMay 22, 2018Sr. NETGEAR Moderator
This link should have the firmware that you are looking for.
http://www.netgear.es/support/product/WN2000RPTv1.aspx#download
DarrenM
- chairman212121Jan 02, 2019Aspirant
Shame, but downgrading the firmware didn't help, despite some suggestions. In fact it seemed to make it worse. This item really is limited to about half a megabyte transmission speed. When you go above that, it consistently crashes/freezes.
