John_ncrr
Nov 08, 2022Follower
Orbi AC2200 Tri-band WiFi Router (RBR20) -add extra-strong satellite
I have a good stable Orbi AC2200 but have moved into a unit and need to add a satelite with extra boast to get the signal through a concrete floor (no options for drilling for wired connection or powerline solution). Do I have to stick to a certain type of Orbi when I buy an extra satelitte - which Netgear product would mesh with my Orbi system *AND* give me a powerful signal to penetrate the concrete :).
Thanks
John
the ones you can use is RBS20, RBW30, RBS40, RBS40V, RBS50, RBS50Y
Any chance there's coax ran throughput? moca adapters work well
1 Reply
