Allend04's avatar
Nov 11, 2018
Outdoor signal strength
Nighthawk X6 R7900, Having problems with signal strength outside my home.  I have several ring cameras and they all show a signal strength of -60 or more.  My nighthawk is located in the center of my...
  • StephenB's avatar
    Nov 12, 2018
    I get decent wifi outside with Orbi, though my Arlo cameras are using the Arlo base station.  My construction is wood, not brick.
    You've tried two different extenders with poor results, which suggests that trying yet a third indoor extender is a bad idea.  You probably need something outside.
    If you have a sheltered outdoor outlet (well protected from rain by a porch, or perhaps in a garage or shed) you could try putting a powerline extender like the PLPW1000 in that location.  If you have cold winters, you'd probably exceed it's operating temperature range, but it might still work.
    It is also possible to purchase/install an outdoor AP.  Netgear doesn't make them, but there are other companies that do (including TP-Link).  If you get one that supports power-over-ethernet (most would), you'd only need to run cat-6 through the wall to the AP location.  If you install it near the roof line (under the eaves) you might be able to avoid drilling through the brick. You would want to use cable that's rated for outdoor use.
