Allend04
Nov 11, 2018Tutor
Outdoor signal strength
Nighthawk X6 R7900, Having problems with signal strength outside my home. I have several ring cameras and they all show a signal strength of -60 or more. My nighthawk is located in the center of my...
- Nov 12, 2018
I get decent wifi outside with Orbi, though my Arlo cameras are using the Arlo base station. My construction is wood, not brick.
You've tried two different extenders with poor results, which suggests that trying yet a third indoor extender is a bad idea. You probably need something outside.
If you have a sheltered outdoor outlet (well protected from rain by a porch, or perhaps in a garage or shed) you could try putting a powerline extender like the PLPW1000 in that location. If you have cold winters, you'd probably exceed it's operating temperature range, but it might still work.
It is also possible to purchase/install an outdoor AP. Netgear doesn't make them, but there are other companies that do (including TP-Link). If you get one that supports power-over-ethernet (most would), you'd only need to run cat-6 through the wall to the AP location. If you install it near the roof line (under the eaves) you might be able to avoid drilling through the brick. You would want to use cable that's rated for outdoor use.
Nov 11, 2018Guru - Experienced User
Allend04 wrote:
Nighthawk X6 R7900, Having problems with signal strength outside my home. I have several ring cameras and they all show a signal strength of -60 or more. My nighthawk is located in the center of my home and is less than 40 feet from my cameras. I have tried indoor extenders but no help. Any suggestions
The Nighthawk is almost certainly running at the max power level that's allowed in your country.
What is the house construction? Do you have steel (either rebar or studs) in the outer walls?
Also, were the extenders at or near the outer wall of the house? What models were you using?
Allend04
Nov 11, 2018Tutor
The house is 2x4 with brick on outside. I’ve tried two different extenders one netgear and the other Ring Chime pro. The netgear preform worst than the pro but neither work well. I’ve tried it in several different locations both interior and exterior walls. I’ve relocated my router also with no difference in outside signal strength. Currently the router and one camera are both about 7 feet high(above floor) and 22 feet apart with a window on the outer wall and have very poor signal strength.
- StephenBNov 12, 2018Guru - Experienced User
