Pelagia
Dec 26, 2016Follower
Password Issue netgear wn3000
I'm not computer literate so please be kind. I set my extender up and it worked perfectly well; however, I upgraded my router to a BT Smart Hub. I reset the wifi extender back to factory settings a...
DarrenM
Dec 28, 2016Sr. NETGEAR Moderator
Hello Pelagia
Try to log into the extender again you may need to connect a ethernet cord directly from a pc to the extender or try to use a pc connected to your main router go to www.mywifiext.net login with admin/password and try to change the password then try that password to connect to it.
DarrenM
