GAHL
Dec 08, 2016Aspirant
Password issues with NetGear EX6150v2
I just installed my Netgear EX6150v2 Wifi Range extender, following the instructions. The password I set up does not work, and I can't gain WiFi connection thorugh the extender. All of the recommende...
- Dec 12, 2016
Hello GAHL
on a pc connected to the main router try to go to www.mywifiext.net see if it lets you login to the extender. If not try connecting a laptop to the ethernet port of the extender and try to login. If that does not work you may need to factory reset the extender by holding the reset button for 10 seconds then try the setup again.
DarrenM
DarrenM
Dec 12, 2016Sr. NETGEAR Moderator
Hello GAHL
DarrenM
- GAHLDec 14, 2016Aspirant
Thanks-that solved the problem.
