Whowe3rd
Jul 21, 2014Novice
Password issues
I have a WN3000RP extender that I just factory reset and reinstalled...it sees the network and sends out a network_ext signal but it won't accept the password which I have verified....
jmizoguchi
Jul 21, 2014Virtuoso
Is it something was working before with same device you had ?
It is pc you are trying to connect?
Did you try deleting the wireless profile first and try again if this was pc. ?
