gelstne
Feb 17, 2019Aspirant
password not recognised -Ex2700
Hi
Just Purchased an EX2700 to extend our WIFI into the further reaches of the house - not that far actually but thick old walls !!
Everthing worked as per the instructions - used WPS function al...
Christian_R
Feb 21, 2019NETGEAR Employee Retired
Hello gelstne,
You can log into the extender's admin page by going to www.mywifiext.net. If they have not been changed, please login using the default credentials (Username: admin - Password: password). From there you should be able to locate the network key/password.
~Christian
gelstne
Feb 28, 2019Aspirant
Hi thanks for the solution
But at the risk of sounding ignorant of all thing IT :-) how do I connect to my extender via the fixit adress. I cant connect to the extender on wifi as the password does not connect.
Can use an ethernet connection but again what is the process once plugged in that will get me into the extender
Again sorry if this is obvious
Thanks
- Christian_RMar 06, 2019NETGEAR Employee Retired
Hi gelstne,
Were you able to locate the network key when visiting the extender's admin page?
~Christian
