Aceef's avatar
Aceef
Follower
Aug 01, 2018
Password not working
Hi! I have a problem connecting to the wifi range extender. It says that that I should use the new extended wifi network name and the same password I use for the wifi. The problem is that I do exactl...
  • DexterJB's avatar
    Aug 01, 2018
    Hi Aceef,
    Welcome to the community!
    Pleas make sure you have gone through the setup process of connecting the extender to the main wireless network. This linkmay help out.
    Dexter
    Community Team
