Mattey
Jul 31, 2018Aspirant
Password on AC750 model EX3110
I cant connetct to my new WIFI extender. It´s online and connected to my WIFI at home but when i try to write the password I just get a notice that it´s wrong.
I have tried the same password thats...
DexterJB
Aug 01, 2018NETGEAR Moderator
Hi Mattey,
Welcome to the community!
It would be best to reset the extender and configure it manually and make sure that it uses the same password as your main network. Page 33 of the user manual on this link and the installation guide here may help out.
Dexter
Community Team
- MatteyAug 02, 2018Aspirant
Hi and thanx for the setup.
only problem now is that on my router it dosent show the extender.
All the light`s on the extender is on so it should be online but wont show up on the side.
any idea? can it be that it`s not online after all?
Thanks again, Mathias
- DexterJBAug 06, 2018NETGEAR Moderator
Hi Mattey,
1. Have you done the reset and setup process?
2. During the setup, the extender should find the signal of your router if it is within range.
3. Once you have the extender connected to the router's signal, then the extender should be online.
4. Once you have confirmed that it is, then you can relocate the extender (ideally in a location where it still gets a good signal from the router).
Dexter
Community Team
