Dantastic
Jun 29, 2018Aspirant
Physical location for Multiple EX8000 (X6S) Range Extenders
Hello, I've looked through this forum and online and cant seem to find the answer I am looking for.
Its looking like I need two range extenders with my router to get the coverage I am looking for. I have a Nighthawk X10 router and I plan to pick up two X6S (EX8000) extenders.
What is the most efficient way to position these devices?
Should I connect them this way:
Router > Extender > Extender
OR is it possible to have both extenders connected to the router?
Extender < Router > Extender
Currently my router is central to my house but I dont have a problem repositioning it to accomodate the most approprate setup above.
Also, if I am strictly looking for best speed, and am willing to lose the single SSID name, which is faster -- the range extender wirelessly connected to the router or the extender directly wired to the router in AP mode?
thank you for your help,
dan
Hi Dantastic,
Welcome to the community!
A wired setup is always recommended to get the most bandwidth as there are lesser variables to deal with which makes setting up the extender in AP mode the most ideal if your priority is speed especially if you already have the network setup (Ethernet wall patches and/or if you don't mind long Ethernet cables). As far as the wireless options, Extender < Router > Extender is the better option/positioning since you will lose speed with an extender to extender connection.
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Dantastic,
Dexter
Community Team
- DantasticAspirantThank you, I appreciate your help!
Dan
