arvesper's avatar
arvesper
Please recommend WiFi Range Extenders compatible with WNDR4500v3
1 Reply
  • plemans's avatar
    the WNDR4500v3 is a N900 router. Do you plan on upgrading in the future to a better router?
    How large of an area are you trying to cover?
    What is the usage case for this? reason I ask is there are standard extenders, dual band extenders, and tri-band extenders that use a wireless backhaul for connecting back to the router.
    Alot depends on your usage goals, house size, and budget.
