JohnDH
Dec 09, 2018Follower
Plugging Powerline into an outlet splitter
I have a standard duplex wall outlet. I have a 4 plug outlet splitter/adapter plugged into it.
I know the Powerline directions say not to plug the Powerline unit into an extension cord or power s...
Dec 09, 2018Guru - Experienced User
The concern overall is that the extension cord or splitter will reduce the performance of the powerline network. A surge protector or UPS will have a bigger effect than a simple extension cord or an outlet splitter, since they are filtering the powerline. I doubt you'll see any issue with the splitter - I've tested a couple powerline devices using them, and I didn't see any performance problems.
It's safe to connect up the powerline that way, so maybe try it and see if you get good enough speeds.
