Niki001
Mar 27, 2020Aspirant
PLW1000v2 : disable PLC and make it just a WiFi point by ethernet
Hello, I have 2 PLW1000v2 (and mabe I'm going to buy 2 more). I would like to disable the PLC. I would simply connect them by Ethernet to my ISP Box. They will broadcast WiFi with ethernet conn...
Mar 27, 2020Guru - Experienced User
What do you mean by disable PLC?
- Niki001Mar 27, 2020Aspirant
PLC = Power-line communication
= Network in power cable
= main technology of the product
- plemansMar 27, 2020Guru - Experienced User
the whole purpose of the poweline device is its powerline. If all you're wanting is the wifi AP, you'd be better off with a range extender in AP mode.
I've never seen an option to turn off the powerline connection on these devices.
