stevenwb11
Jul 30, 2016Aspirant
Port forwarding for CCTV
I have a CCTV unit plugged into my EX700 Nightwawk Extender by a LAN cable My extender is connected to my Virginmedia Superhub 2 via wifi. I can use both the 2G & 5G around the house without problem...
TheEther
Jul 30, 2016Guru
When it comes to port forwarding, range extenders are invisible, so you do not need to forward to the EX7000. Change the port forwarding rule to forward to the IP address of the CCTV unit instead of the EX7000.
stevenwb11
