enwulff
Apr 28, 2013Aspirant
Port Forwarding through WN3500RP
I have a security camera on the far corner of my house that was not connecting in well with the AT&T 2Wire router. So I bought the Netgear WN3500rp and set it up to connect to my 2wire router. I can access the camera feed via the extender without any issue, but the problem is that the port forwarding doesn't seem to be working. When I go under the firewall setting, The IP address is just 0.0.0.0 and I set it up the same way I set up all the other cameras on the 2wire router to do port forwarding. If I set the camera to access the 2wire router directly, the port fowarding works and I can access it via the external IP address. The question is how do I get the portforwarding to work when the camera is connected via the extender. Thoughts?
- acabanoNoviceI have exact the same setup, existing setup with 2wire router and foscam IP wireless camera works fine with the IP cam iphone app, but with the WN3500RP no joy! but i was able to access via web browser 172.16.0.1:8080 from my laptop using myextender_2.4GXET please help. is there anything I'm missing?
- marc311Aspirant
acabano wrote: I have exact the same setup, existing setup with 2wire router and foscam IP wireless camera works fine with the IP cam iphone app, but with the WN3500RP no joy! but i was able to access via web browser 172.16.0.1:8080 from my laptop using myextender_2.4GXET please help. is there anything I'm missing?
you cant do any port forward/trigger on the extender since this device rely on the main router. If you can access IPcamera locally/remotely from main router then it should be working as well when connected to extender either wired/wireless.
