acam6146
Dec 11, 2018Aspirant
Powerline 2000 connected. Printer working, but not internet.
Hi,
I have created the following setup to extend internet from the living room to a home office:
internet - Netcomm NF18AC Modem Router - two cables - PLP2000 - through walls - PLP2000 - (1) ...
acam6146
Dec 12, 2018Aspirant
I should add that I want to access the internet from the second router wirelessly. This is all setup in the router and like I said, was working well at the beginning.
When I plug my computer directly into the ethernet port of the powerline in the office, I still do not get internet, although I have a stable connection to the main router.
- StephenBDec 13, 2018Guru - Experienced User
Getting this to work will likely solve your main problem.
Can you "ping" the main router when you connect your computer directly to the powerline ethernet?
Can you see if the PC is getting an IP address that is compatible with your main router's network?
BTW, the usual way to do this would be to set up the Netgear router as an Access Point, and not use it as a router. If you can post the router model (N300 is actually a speed rating), then we can find out if that is possible.
- acam6146Dec 13, 2018Aspirant
Thanks for Responding Stephen.
The Ping request times out when pinging the main router from the powerline ethernet. When connected to the main router, I can ping the second router successfully.
The second routers model is DGN2200v4. The second router is really just acting as an access point (I think???). The second router is setup as a fixed ip on the main router, DHCP is disabled and you can see the devices logged into the main router when viewing the netgear genie from the second router.
Not sure if this helps but when I'm wirelessely logged into the second router and I ping the printer, I'm receiving "Destination host unreachable"
Also, when I'm connected to the second router, I cannot browse the ip for the main router. When connected into the main router, I can browse the ip's for both routers.
- StephenBDec 14, 2018Guru - Experienced User
That model does have an AP mode you can enable from the web ui - that might be better than trying to create an AP mode manually.
But if you want to stick to doing it manually, you also should be connecting the ethernet to a LAN port of the DGN2200, and not it's WAN port.
Can you let us know the local IP address of the router (usually 192.168.x.x), and the IP address of the PC when it is connected via powerline ethernet? Local IP addresses aren't routable, so it is safe to post them.
