tosalet's avatar
tosalet
Powerline 500 XWN5001 setup
System has been working fine for a long time. However, now a change of router requires a new setup. Used Netgear Genie to map the network then the first problem was a constant failure to 'Factory Res...
  • tosalet's avatar
    Jun 21, 2016
    Finally solved my own problem. Netgear had changed the system to set up the wireless configuration . . .
