INOURIDER's avatar
INOURIDER
Powerline and/or a range extender-will it help me?
I just did a speed test.  Download speed is 0.27 Mbps and upload speed is 0.41 Mbps.
As you can imagine watching Netflix is a major pain.  MY ISP has no intention of doing nothing but to keep ripping me off.  Will a power line range adapter or a range extender help me out?
I have a Netgear AC 1200 R6120 model router.
Thanks
  • plemans's avatar
    Thanks
    Need just a little more info to appropriately answer this question.
    What speeds are you paying for?
    Is this cable, dsl, etc.
    What is your gateway?
    What speeds do you get hardwired to your gateway?
    What sized area are you covering? The speedtest you're quoting is at what point?
    • INOURIDER's avatar
      INOURIDER
      I am paying for 3Mbs.
      DSL
      1200 sq ft house
      Gateway-192.168.1.1
      Hardwired- DL .33Mbs UL .60Mbs
      • plemans's avatar
        DSL
        1200 sq ft house
        Gateway-192.168.1.1
        If the fastest speeds you can get  Hardwired is DL .33Mbs UL .60Mbs then a range extender/powerline isn't going to help much. You'd need to get that improved to see much a of difference with an extender or powerline.
        Either a different dsl modem that can do a little better with limited dsl strength or you can work with your dsl provider to see if they can add a dsl loop extender to boost their signals. Some providers will possibly do it but not many as its expensive.  Or see if there's a way to switch providers..
        have you ever been able to hit 3mbps?
