furyfrog
Nov 17, 2015Aspirant
PR2000 Log in to network with Username/PW
Hi, I'm using Navy GoWiFi as my primary internet connection. This service requires a Username/pw to access the internet. I'm trying to use the PR2000 as a LAN to connect all my devices behind it's fi...
nhann
Nov 18, 2015NETGEAR Employee Retired
Hi furyfrog,
Can you please clarify your network map?
Is it the following?
Navy GoWiFi ----wire----PR2000 - - - WiFi - - - devices
Is your PR2000 set to Wired mode?
Is the PR2000 updated to the latest firmware version 1.0.0.14 ?
- furyfrogNov 18, 2015Aspirant
Hi nhann,
My attempted network map is:
Navy GoWiFi - - - wifi - - - PR2000 - - - wifi - - - devices
It is set to wireless mode, and I have updated it to 1.0.0.14.
It says it sees the gowifi network and connects and it lets my devices connect on the other side.
- nhannNov 19, 2015NETGEAR Employee Retired
Hi furyfrog,Please reset the PR2000 back to factory defaults.
You can try updating the NavyGoWiFi router and/or resetting it to factory defaults also.Also try changing the WiFi channel on the router to a channel that is less crowded / used by neighboring networks.
If your issue still occurs, please contact Support:
