furyfrog
Nov 17, 2015Aspirant
PR2000 Log in to network with Username/PW
Hi, I'm using Navy GoWiFi as my primary internet connection. This service requires a Username/pw to access the internet. I'm trying to use the PR2000 as a LAN to connect all my devices behind it's fi...
furyfrog
Nov 18, 2015Aspirant
Hi nhann,
My attempted network map is:
Navy GoWiFi - - - wifi - - - PR2000 - - - wifi - - - devices
It is set to wireless mode, and I have updated it to 1.0.0.14.
It says it sees the gowifi network and connects and it lets my devices connect on the other side.
nhann
Nov 19, 2015NETGEAR Employee Retired
Hi furyfrog,
Please reset the PR2000 back to factory defaults.
You can try updating the NavyGoWiFi router and/or resetting it to factory defaults also.
Also try changing the WiFi channel on the router to a channel that is less crowded / used by neighboring networks.
If your issue still occurs, please contact Support:
