KarlEileensson's avatar
Feb 08, 2019
Printers on base router can they be used via the wifi extender?
I have two printer connected by cable to my modem wifi router. Can I reach them from the X4S without having to re-add them, or, do I need to add them again via the X4S range extender. I like the fact that it uses my existing SSID.
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello KarlEileensson - Yes, you should have no issues reaching the printers assuming the printers are network printers and are all under the same subnet or IP range.
    ~Christian
