stroebi
Dec 07, 2011Aspirant
Problem discovering WNDAP360 with WMS5316
Hy folks, WMS5316 Firmware v2.1.2 WNDAP360 Firmware v2.1.1 Both in factory setting After reading some topics with the WNDAP350 I found out that the WMS5316 discovers the AP by sending a SNMP-...
zpower
Jan 31, 2013Novice
That's weird, initially I could see your screenshot.
Anyway, I have no idea why the AP would be sending information to an address not in your network. Maybe it has some held over information from when it was tested at the manufacturer. When I was having these problems, one of the things I had to do was update the AP to the latest firmware, and after doing that reset the AP to factory default. Maybe you could try that to see if it helps.
