stroebi
Dec 07, 2011Aspirant
Problem discovering WNDAP360 with WMS5316
Hy folks, WMS5316 Firmware v2.1.2 WNDAP360 Firmware v2.1.1 Both in factory setting After reading some topics with the WNDAP350 I found out that the WMS5316 discovers the AP by sending a SNMP-...
cwolfram
Feb 01, 2013Aspirant
zpower wrote: When I was having these problems, one of the things I had to do was update the AP to the latest firmware, and after doing that reset the AP to factory default. Maybe you could try that to see if it helps.
I tried that about a dozen times. Always the same problem. I even took another AP (also a WNDAP360) to see if it has the same problem. It did.
Time for Netgear Support I guess. :/
