Kirkruns1
Mar 06, 2016Tutor
Problem setting up WNR614 as Wifi Repeater / Range Extender
I recently had to reset my r7000 nighthawk router - when I did the extender won't connect - I have tried with both an ethernet cable and mywifiext.net. Other suggestions?
TheEther
Mar 06, 2016Guru
Did you do a factory reset of your R7000? If so, the reset will have reverted the R7000 to its factory configured Wi-Fi settings. You will need to change the Wi-Fi settings to whatever they were before the reset. Once you do that, the extender should work. Or else change the extender to work with the new Wi-Fi settings.
