Kirkruns1
Mar 06, 2016Tutor
Problem setting up WNR614 as Wifi Repeater / Range Extender
I recently had to reset my r7000 nighthawk router - when I did the extender won't connect - I have tried with both an ethernet cable and mywifiext.net. Other suggestions?
Kirkruns1
Mar 07, 2016Tutor
I did reset to factory - but mywifiext.net will not pick up the new or old settings on the extender?
TheEther
Mar 07, 2016Guru
Can you confirm that you reset the R7000 to factory defaults?
I didn't understand what did you meant by "mywifiext.net will not pick up the new or old settings on the extender". Visiting mywifiext.net will not cause the extender to automatically pick up the R7000's Wi-Fi settings.
If you have WPS enabled on the R7000, then you can use it to transfer the Wi-Fi settings to the extender, but that's different than visiting mywifiext.net.
Can you clarify what you tried to do?
- Kirkruns1Mar 07, 2016Tutor
I tried using the WPS feature on the R7000 but it will not connect that way – then I tried using an Ethernet cable when that didn’t work I went to mywifiext.net – but it says I have no connection. I’m frustrated
- TheEtherMar 07, 2016Guru
Sigh, more questions than answers.
How did you connect the Ethernet cable? Between a computer and the extender? Or between the extender and the R7000?
In order to set up the extender you need to connect a computer to it via either Ethernet or Wi-Fi. If you use Wi-Fi, then the computer needs to join the extender's Wi-Fi network. Only then will mywifiext.net stand any chance of working. If you join the R7000's Wi-Fi network, then mywifiext.net will probably not work.
enabled wps function on router and it worked
