BarryJI
Nov 23, 2016Aspirant
Problems installing a second booster: WN1000RP
Hello, this is probably a simple, even generic issue (at least I hope so) but I'm scratching my head over it and would really appreciate guidance. I just bought two WN 1000RP boosters. I was abl...
- Nov 29, 2016
Bingo! After disconnecting #1 and setting up #2 per the manual's instructions via WPS, both extenders are showing up in Attached Devices (where neither was there before, mysteriously) and appear to be working. They have the same SSID but discrete IP addresses. The USERNAME_EXT is the only one that shows up in my iPhone's list of available wifi networks but I guess I was mistaken to expect this to be any different with two extenders. Having found the devices via my browser as you suggested, I took the opportunity to update their firmware and that went smoothly. I also updated my router's fiirmware via the router interface. Both devices now show CONNECTED but one reports 54 mbps link rate and the other 11 mbps.
Thank you for your patience and expertise.
This is a fairly technical process for the average homeowner with a wifi network I can imagine that the various interfaces, the passwords for router, wifi and service provider and the tech protocols may be too much for most people to master by themselves. I managed because I am reasonably competent around computers and because you were so helpful. There must be plenty of people who are floundering though; I mean, how often would they even think to update firmware, or know how to? I am very grateful for your assistance.
BarryJI
Nov 29, 2016Aspirant
Update: I have now found my way into the Netgear Genie, from which I can access my router settings, etc. I see no way through this menu to access the one connected Netgear extender, however. I might try the second suggestion , i.e. to unplug Extender #1 while configuring Extender #2 but I am pretty sure I tried this before.
DarrenM
Nov 29, 2016Sr. NETGEAR Moderator
Hello BarryJI
If you are connected to your routers interface try going to the attached devices page and find out what the Ip address of the extender is then take that Ip address and put that into your web browser and it should then prompt you to log into the extender.
DarrenM
- BarryJINov 29, 2016Aspirant
