Fionncraik's avatar
Fionncraik
Product EX6110 won’t connect to WiFi router for more than 1 second
When I connect my router to my WiFi extender though wps it connects for a second then disconnects and it says no internet on my phone. I have reset the Netgear extender and nothing changed I have done the same with the router. 3 out of the four green lights show on the device the only one that doesn’t show is the router one. Anyone have any advice how to fix this?
    • Fionncraik's avatar
      Fionncraik
      It won’t connect to the internet but I will connect to the router I think that is the problem. The access point is made but the router doesn’t detect an internet connection even though there is one. Any advice?
      • plemans's avatar
        What router are you connecting it to?
        What modem/gateway is the router connected to?
