harropenk's avatar
harropenk
Question using the AC750 to connect WiFi signal to an ethernet device
This question pertains to using the AC750 EX3700 WiFi range extender to connect a single ethernet device.  We have a printer which needs to be connected via WiFi and we can't run cables due to where it is located.  The question is if the EX3700 will pass-through the IP address, or will it give the connected device (a printer) a completely different subnet address.  We've already tried a couple of other devices and upon arrival we've found out that those devices unfortunately create separate IP address domains.  Our WiFi IP range is 10.1.0.0/24, and we need the printer to also be on that same subnet, so before we spend more time and money on an EX3700 I need to know if this will pass down a 10.1.0.0/24 IP address on the ethernet port, or will it create some kind of 192.168.0.0/24 (or otherwise) separately routed subnet?
Thanks in advance, have a nice weekend.
  • plemans's avatar
    It should use the same IP range as the router. I've ran multiple netgear extenders and they've all used the same IP range as the primary router.
    • harropenk's avatar
      harropenk
      Hi,
      Thank you for your reply.  Perhaps I didn't ask my question correctly, but I think your answer doesn't address my problem:
      (1)  We wouldn't be using this as a WiFi extender.  Instead, we're trying to connect a wired ethernet printer to our corporate wireless network.  The netgear unit has an ethernet port, which according to directions/specifications can be used to connect wired devices to wireless.  Your answer would only address trying to connect a wireless device via a bridge mode.  We've actually tried that with a couple of competing devices, and sure enough - they put the printer in a completely different subnet.  And .... because those devices routing capability was so low-end, we couldn't make changes or get it into a pass-through mode.  Heck, even connecting to our WiFi was kind of iffy - we usually keep the corporate SSID hidden, but the way to connect to the network required a visible SSID.  Easy enough, we made it temporarily visible just to connect this (ultimately not viable) WiFi-to-ethernet converter, but all of that could have been alleviated if they just allowed users to type in the SSID.
      (2)  So again, if using this device as a WiFi-to-(wired) ethernet converter, does the unit change the subnet or does it maintain the same subnet at the WiFi?  Is is a router or a hub/switch in that mode?
      • plemans's avatar
        I understand that you're not using it as an extender.
        But in extender mode, it allows you to use the ethernet port as a direct connection in the same subnet.
        I don't know what devices you used prior or how you set it up, but whenever I setup a device hardwired into an extender, it pulls the same subnet as my network.
        And hiding your ssid doesn't make it any more secure.
