S1DIMMER
Jun 08, 2014Aspirant
R7000 Nighthawk wired to EX6200?
I just purchased the R7000 Nighthawk router and while the speed increase has been fantastic the range has not been great. Setup was simple, I installed it in my basement where my old DLINK N router w...
Retired_Member
Jun 09, 2014The easiest thing to do is use same SSID and security If it does not latch onto to strongest AP Signal, for IOS devices toggle WIFI OFF and ON for PC just disconnect then reconnect it's quite simple and works great. I do more than I care to admit when testing. Or reboot device as your signal level drops.
