S1DIMMER
Jun 08, 2014Aspirant
R7000 Nighthawk wired to EX6200?
I just purchased the R7000 Nighthawk router and while the speed increase has been fantastic the range has not been great. Setup was simple, I installed it in my basement where my old DLINK N router w...
Retired_Member
Jun 09, 2014You need to get it out of the basement. Forget the antennas unless you're getting a set for the clients as well.
