S1DIMMER
Jun 08, 2014Aspirant
R7000 Nighthawk wired to EX6200?
I just purchased the R7000 Nighthawk router and while the speed increase has been fantastic the range has not been great. Setup was simple, I installed it in my basement where my old DLINK N router w...
jmizoguchi
Jun 09, 2014Virtuoso
You are in the bad place... You do not want to any more that -50 reading on signals.
Place the router in the first floor would more suitable and place another extender and spend more money. If broadband modem is located in the basement and can not move then try find the way to run ethernet cable to the first floor.
