S1DIMMER
Jun 08, 2014Aspirant
R7000 Nighthawk wired to EX6200?
I just purchased the R7000 Nighthawk router and while the speed increase has been fantastic the range has not been great. Setup was simple, I installed it in my basement where my old DLINK N router w...
S1DIMMER
Jun 14, 2014Aspirant
So I moved the router to the first floor and it's working reasonably well. I have a usable signal all over the house, at least on the 2.4Ghz band. Second floor also worked but seems a shame to spend the money for this router then use it as just an access point. So I'm going to pickup some higher gain antenna and try it again in my basement replacing my DLINK router. If that doesn't work I may just put it back in my office on the second floor and keep the DLINK in place as the main router. In the future I'll remember to run at least 2 cat 5e or cat 6 cables to each room instead of just one.
