fleetmack
Feb 01, 2019Aspirant
R8000 with EX7300
I have a Nighthawk R8000 with an EX7300 acting as extender. I learned this morning I can upgrade the EX7300 and use it as mesh so I don't have separate networks in my house. Awesome! Now -- can I us...
Christian_R
Feb 06, 2019NETGEAR Employee Retired
Hello fleetmack - Absolutely! This would still be considered a mesh network. Give it a try and let us know what you think!
~Christian
fleetmack
Mar 25, 2019Aspirant
I have never been able to get this working, I've seemingly tried everything. This article seems to state that to used wired ethernet, I need it in access point mode, which will disable same ssid:
Every way I've tried this, my wifi breaks if I plug the ethernet cable into the extender. I simply want the ex7300 to support same ssid while getting its signal from an ethernet cable instead of from a wifi signal. Is this possible? Seemingly, no ....
- FURRYe38Mar 25, 2019Guru - Experienced User
What FW version are you using on the EX?
When setting up the EX for AP mode, do you get the selection to see either AP mode or extender mode during the initial setup?
If you can set the AP mode during setup, and get to the main web page of the EX, I would input a static IP address ON the EX, 192.168.1.73. Besure yout set your routers IP address pool size to 192.168.1.100 to .200. Then this will give you room on each side to set static IPs ON devices on either side of the default IP address pool. Once the address is set. Reboot and while it's rebooting, connect the LAN cable to the EX from the main host router.
I do this for my EX7700. 192.168.#.77 and I can access it from anywhere in the home.
